Originally Posted by
karolh
When setting up a rudder pull pull system, just how tight should the pull pull cables be so as not to preload the servo output shaft bearing
Karol
Might I suggest what I do too. I hang at least a 10# wt on the wire for about a week prior to installing. This takes the stretching out that will happen. You want to make them as tight as possible, due to they will stretch even more over time
