I wanted to install the Smart-Fly PowerExpander Competition 12, receiver, and batteries last so they could be mounted where needed to achieve the desired CG. I moved back to the tail to complete those installations.
The first time I put the horizontal stabs on I was amazed at the perfect fit between the fuselage and the stab roots. It was beautiful.
The bolts into the stab tube were drilled perfectly by the factory and positioned the stabs tight against the fuselage.
