dual rates is all set up, ever since the second test flight
i'm happy with all my throws and expo in both, as comfirmed by all that have flown her... they are still amazed that flicking a switch changes the way the plane flys, even in a straight line. somehow even when you'r not touching the sticks it smooths out!!
what i'd like is a 3rd switch i can flick to make the elevator go through this 170 degrees movement under control.
