RE: Converting RC engines to Control Line
Danger! Will Robinson!
Warning! Warning! Fox blasphemie with C/L experts and devout fans is bad for you!
You have obviously shown your hand by not knowing about the infamous Fox burp. The Fox .35 stunt is really a fine engine when used as it was intended. Only problem is the crappy needle. And maybe the fact you can't get it out of the box in ABC form.
