RE: Modeltech Magic Extra 300L
I have a question for all of you Magic Owners:
How was your wing mounted to the Fuse?
Did you have to drill the holes yourself, and add blind nuts? Or was this already done for you?
The reason I ask, is that I am currently reviewing this plane for RCU Magazine, and on mine, the instructions say to do the drilling yourself, but the wing hold-down block was predrilled with blind nuts installed, yet the wing was NOT drilled. This caused the only assembly problem as I could not drill holes in the wing that would line up correctly with the existing nuts (I solved the problem by simply removing the nuts, plugging the holes, and redrilling them).
But I am curious as to the state that other models were in pre-assembly.
(Note: My firewall and Landing Gear blind nuts were also pre-installed)
