RCU Forums - View Single Post - Ive started another....
Old 09-05-2013 | 05:20 AM
  #39
SteveR3750
Originally Posted by speedracerntrixie
Lusterkote does not play nice with Rustolium. I found out the hard way. Mine was gloss clear and I was trying to apply a nice wet shiny coat. If you go with the flat clear and mist on very light coats you may be OK. I would do a test piece before spraying the airplane. Great looking airplane though. it's really tough to get results like that with today's Monokote
Thank you for that information!! I have not sprayed it yet and will make sure to use a test piece. I have read that Rustoleum by itself is fairly fuel resistant unless you leave the residue on for an extended period before wiping it off. I may just leave it like it is and forget about the Lusterkote.
I know there are many threads out there for weathering, but does anyone have any quick tips on how I might weather this plane directly over the monokote? I do not own an airbrush and I would like to try an add some weathering to this plane.
