RCU Forums - View Single Post - DLE-35RA Issue
Thread: DLE-35RA Issue
Old 09-08-2013 | 04:05 PM
aerobatixkid's Avatar
aerobatixkid
Default DLE-35RA Issue
DLE 35RA
Tech-aero IBEC (unregulated, powered by an A123)
32:1 Amsoil Dominator / 91 Octane (Highest octane available here)
NGK CM6 .025gap
Hi all.
Received this engine last week from a distributor here in Canada.
I've had a few issues with hard starting and now I am having an problem with
the engine not coming down to an idle for 15-20 seconds after the throttle is
closed. It seems to "hang" at a certain rpm and then it will come down to an
normal speed. I've been flying and tinkering with gassers for about 3 years and
this is the first time I have expirenced such an issue.
It does this at the stock needle settings, and I have tried tuning it out of the
engine with no success. Only way I can reduce the time, is to richen the low to
an excessive amount, and then it has no choice but to come down to an idle
because its starting to flood itself out.
Any insight is much appreciated.
Shane.
