Thanks for the update John and great on your flight tests. I gather you are one of the lucky ones if you have the wire U/C. I got the "floppy" gel
gear and questioning whether I even install it! I may have to learn how to form spring steel!!My setup is going to be 6S 15/8 prop.
-did you encounter the elevator trim issues referenced in the past? was the setup up per BJ's documentation?
-did you install the rudder update "dive brake"?
Just curious!
