RCU Forums - View Single Post - FOCUS 1 question
Old 09-16-2013 | 08:40 PM
flyboy91
Jerry,
Your best bet will be hook up 2 6"-12" Extensions coming from your receiver to outside the fuse. That way you can just plug in your ailerons outside the fuse, once connected just slide the connector back inside the fuse and your all set. If you do this method I'd recommend getting these http://www3.towerhobbies.com/cgi-bin...&I=LXDT85&P=ML
They will ensure the ailerons stay connected during flight.
Andrew
