FOCUS 1 question
Old 09-16-2013 | 01:43 PM
My Feedback: (9)
Default FOCUS 1 question
I am putting this model together and have realized that to access the fuselage internals one must remove the pipe tunnel.
Figuring that many who watch this forum have built this model, was wondering if there is an easier way to hook up the aileron servos when mounting the wings without removing the tunnel?
thanks in advance.
Jerry
Old 09-16-2013 | 08:40 PM
Jerry,
Your best bet will be hook up 2 6"-12" Extensions coming from your receiver to outside the fuse. That way you can just plug in your ailerons outside the fuse, once connected just slide the connector back inside the fuse and your all set. If you do this method I'd recommend getting these http://www3.towerhobbies.com/cgi-bin...&I=LXDT85&P=ML
They will ensure the ailerons stay connected during flight.
Andrew
Old 09-17-2013 | 09:49 AM
My Feedback: (9)
OK , thanks Andrew. I'll give that a try.
Regards,
Jerry
