See that gasoline supply is "on".
Check to see that the gasoline in the tank is high enough to flow to the carburetor.
Make sure that the carburetor float is not stuck and that there is a definite flow of gasoline to the carburetor.
Determine whether main oil tank contains a sufficient quantity or lubricating oil
Remove front set of spark plugs and test compression of each cylinder.
