RCU Forums - View Single Post - Space Walker II by SEAGULL ?
Old 09-25-2013 | 04:18 AM
Granpooba
Originally Posted by bhady
I Put one together earlier this summer. It's a good looking and good flying plane, and seems to like moderate speeds best. It's Kind of a floater when landing. The covering job is excellent, no wrinkles, and has stayed tight. Quality of construction seems to bee good, at least on par with some of the better ARF's I've put together. I powered mine with an OS .70 four stroke. I did use larger wheels and left the wheel pants off since I fly from a grass strip. The fuel tank tubing, some of the hardware, wheel pant attachment method and instructions are the only weak points, but if you have experience with other planes you won't have any problems. I'd get another one in a heartbeat.
bhady
Hi bhady,
Thank you for your input. Yours is the kind of reply that I was hoping for, as I feel that this would make a good gas flyiing model for myself. I also have given up on wheel pants even though our flying field has a combination grass and gravel runways. Also, do not know if it would fit in a Space Walker, but I have a couple of new Roto Flow fuel tanks that I would really like to try in a new model.
Again, thanks for your input.
