RCU Forums - View Single Post - Candy Kane Build Thread
Old 09-26-2013 | 10:44 AM
  #63
sahartman21
Default Candy Kane Build Thread
I used Acrylic Enamel (type with hardener) automotive paint.
I am trying something new this time. I did not apply clear coat over the fuselage paint. I had applied too much paint already and was planning to avoid adding more weight by not applying clear coat.
The surface was wet sanded with 2000 grit wet-and-dry sandpaper used wet. This was followed by various polishing compounds and finished with car wax.
The overall surface has a semi gloss finish and is satisfactory for a Q500.
ID:	1925017   Click image for larger version
ID:	1925018   Click image for larger version
ID:	1925020   Click image for larger version
