RCU Forums - View Single Post - Need Magnet mounting ring for ASP 120 conversion.
Old 09-29-2013 | 01:21 AM
bluejets
Usual approach is to drill a small hole in the back of the prop driver and epoxy the magnet in there.
If it is done in the section at right angles to the prop shaft then no problems with it throwing out at high revs.
This is assuming you are using the ones we generally use, i.e. 3mm diameter and 1.5mm thick.
