ohh ok basically yea only issues would be say putting the old diffs on a new chassis(they will fit just takes a quite a bit of finesse, and sometimes a hammer). Outside that you basically can get a newer truck manual, and just look at what part you need swapped. Even the greater majority of aftermarket parts will fit excluding the RPM center skid plate for the newer savages those require a certain curve in the TVP's.
