It's a little goofy... and I really wish they would include a better manual with this radio, since some of the mixes ARE NOT very intuitive.
Anyway....
1) Set up your flaps, and ailerons in the wing type menu. (not as a program mix)
2) Use a program mix, and then mix the flap switch to the LAL. That will allow you to raise both ailerons. Also... you can assign this to a switch, to turn the mix on and off.
FYI: If you mix to the RAL, I will make the ailerons go opposite of each other.
I just did this myself, and I had to contact one of the Spektum programmer's to get an answer. I wish they would have just kept the terminology the same as the JR radios, where you mix FLP to FLPRN.
