RCU Forums - View Single Post - BJ Craft Monolog 110 for 2012
Old 10-04-2013 | 07:24 PM
  #56
Lazer
My Feedback: (27)
Hello Bob,
Thank you for helping me on this. I do have a question though you may know the answer. When I mounted the motor (electric) I noted that there was up thrust in the shaft of the motor then I noted that the bottom of the laser cut motor mount was noted that the third cut hole from the top cut is 1/8" farther from the front of the fuselage bulkhead than at the top of the mount, but the three degree right thrust is there? I'm not a novice builder as have built award winners over the last 40 years and all parts check out. I know in my heart that this plane was not designed to fly with that much up thrust. Currently the back of the motor is square with the main bulkhead and zero upthrust.
