Hi Guys
I have a few DLE20.
Lovely motor, reliable with good performance, run in on 16X8 Xoar prop, once run in done replaced by 17X6 Xoar, all use a mounting plate available from Seaplane Supply (link below)
http://www.seaplanesupply.com/aluminum.htm
You will also need to replace the throttle lever with one CNC Alloy Throttle Arm for Gas Engines
available from Hobbyking (link below)
http://www.hobbyking.com/hobbyking/s...dProduct=21299
The DLE 20s are mounted on the following
1 on a VQ Cap 10B (Ideal match)
1 on a Pilot RC T90 (Bags of FUN on every flight) can be upgraded to DLE 30 as mounting plate matches DLE 20 to DLE 30 mounting points
1 on a Seagull Ultimate 120 (Ideal match)
1 on a Seagull Yak 54 (Ideal match)
And I am planning to fit 2 on a ASM Grumman F7F Tigercat
and another 1 on a Seagull Dewotine D520
