Originally Posted by
extra 300
Could anyone advise if the Eagle Tree Guardian Gyro (3 axis) is recommended to use in jets?
Thanks in advance
Regards,
There are several people using the ET gyro in jets. I know that Barry from KingTech is flying with it. (That's why he sells it on his website) And... there are a few vids on youtube of the ET gyro flying in turbines.
Bob_B
this unit only has single outputs it also uses trimmer pots to set the gain so. inflight adjustment is not possible.
That's not true. Well.... not totally.
Yes, there are gain pots on the unit, that can be used to adjust the gains. But, you can also control 2D and 3D modes from the TX. AND... you can set the "Master Gain" using a knob, or other open channel from your Tx. (or turn it off)
