Originally Posted by
superduty04
I recently bought a futaba t7c with a R617FS receiver I bound it to model one but when I go to a different model like model ten it still control model one also any ideas what could be causing this? I'm new to futaba just switched from a different brand.
Futaba does not have model match.
If you bind a Futaba receiver to a Futaba Transmitter, it will work regardless of which model memory you select in the Transmitter.
If you are coming from another brand, I assume it was Spektrum or JR with DSM2 / DSMX? They use model match where the receiver is bound to a specific model memory and will not operate on any other model memories in the same transmitter.
http://www.spektrumrc.com/Technology/ModelMatch.aspx
With Futaba, always check you have the correct model selected before powering up the receiver.
