Hi Guys,
In regards to the new smaller RCExl ignition versus the older style RCExl ignition: there should be no difference in the operation or the internals that would cause the issues you are experiencing. The ignition itself should use NO MORE than 500 mAh at wide open throttle. You should easily be able to run a 2000 mA battery for 1.5 hours powering just the ignition (I'm not sure about how much current draw the ibec demands). From the above post, it seems like it draws quite a bit of current.
I have also heard about a lot of guys running the ibec with no issues, maybe some of them can speak to what they are doing to be successful?
Marty H. if you haven't sent your engine in yet, I can confirm that they only need the engine. If they give you any problems with that let me know and I can straighten it out.
Jimmy
