RCU Forums - View Single Post - BJCraft BISIDE
Old 10-15-2013 | 09:35 AM
  #271
serious power
Originally Posted by rcpattern
Easiest way is just use a two servo wing type, then go in and add two more channels, aileron and aileron two. You will have two aileron and two aileron 2. I plug both left ones in aileron and both right ones in to aileron 2. I make those the first 2 channels aileron, channel 3, throttle, and 4 and 5 aileron 2. I did that to keep the grouping. Works great on both of my other bipes. Let's me independently adjust ATV and such, but makes AFR and Dual Rate very easy as well. Haven't set up a BiSide yet, but will do it the same.
Arch
Hi Arch,
With that set up I believe you won't be able to set one wing in spoileron while the other is in flaperon.
Maybe Dave is seeking to try this for braking.
I don't use this myself (not yet anyway) but some do . eg; Juan Rombout.
Brian
