RCU Forums - View Single Post - I learned a big lesson
Old 10-16-2013 | 05:03 PM
Rob2160's Avatar
Rob2160
Originally Posted by loves nitro
Rob2160,
Thanks for the tip, about how much rudder/aileron mix would you recommend?
paul
Hi Paul,
I just had to call my friend as I couldn't remember. We have 35% on the Albatross.
I use an Aileron / Rudder mix on most of my scale aircraft for scale flying, but usually only about 20%-25% and on a switch to disable it for aerobatics.
The Albatross needed a bit more and flies really nice with this setting.
Just to clarify.. It is an Aileron / Rudder mix.. not a Rudder / Aileron mix. The radio sees this as two completely different things.
Basically with the mix on, moving the rudder stick only the rudder will move, but if you move the aileron stick, the rudder also moves in the same direction.
Hope that makes sense.
