RCU Forums - View Single Post - MLD 35 Timing
Thread: MLD 35 Timing
Old 10-16-2013 | 08:50 PM
bcchi
Originally Posted by smkir5
I have a MLD 35 that will not run. I checked the Ign. timing and it is fireing at 45 degrees BTDC. It is not the key or the hub, I think the crank shaft has slipped in the counter weight but I need to know what to set the base timing at?
Depends on which Ign you have. If you have the Melody Ign your guess is as good as mine. If it had a RCEXL or cloan there of.Timing should be 28 degrees before TDC.Don't think crank has slipped. Counter weight is one piece part of crankshaft.
BCCHI
