RCU Forums - View Single Post - BJCraft BISIDE
Old 10-17-2013 | 07:02 AM
  #275
Dansy's Avatar
Dansy
My Feedback: (53)
Originally Posted by checho4
Any of you are using the JR9303 or 9503?
The JR 93/95 doesn't have the 4 ailerons setup as you probably knows, that is the reason I have the JR12X ...but in a tread for the Sebart Miss Wind I found this method which I Didn't try and I'm pasting somebody else solution.....I didn't like that solution because in my opinion it takes way too many mixes to do something that the 12X does naturally without any mixes.....but your welcome to try it.
OK guys I can confirm that you CAN program JR 9303 with a 7 channel receiver to run 4 independent aileron servos and all necessary mixes to run the Ms Wind properly as suggested by Seba. Here is what I have done:
Ch. 1 Throttle
Ch. 2 Right Aileron
Ch. 3 Elevator
Ch. 4 Rudder
Ch. 5 Left Aileron (Listed as Gear Channel on Receiver)
Ch. 6 Right Flap (Listed as Aux 1 on Receiver)
Ch. 7 Left Flap (Listed as Aux 2 on Receiver)
Model type ACRO. In the device selection I have set flaps trim to OFF and to INH as I dont want to accidentally activate these.
Wing type is set to NORMAL, and in the dual section I have mated AILE with GEAR and FLAP with AUX2.
Prog Mix 3: AILE->FROL and under Pos0 set both values to +100%
Prog Mix 4: RTRM->FROL and under Pos0 set both values to +25%
Prog Mix 5: RUDD->AILE, Seba suggests +2% and -2% for both (http://www.sebart.it/download/manual%20DR%20%20expo.pdf)
Prog Mix 6: RUDD->FROL should be identical to previous mix
Prog Mix 1: RUDD->ELEV, Seba suggests +4% for both
Prog Mix 2: THR->ELEV, Seba suggests 2-3mm down
Optional: Prog Mix 2: RTRM->AILE and under Pos0 set both values to +25% (use this mix ONLY if you will be not using mix THRO->ELEV on idle throttle. If this mix is activated all 4 ailerons are trimmed via AUX trim switch!)
