Originally Posted by
rednekk58
I have a SPE 43. It came timed at 40*. I set it at 28*, n starts much easier. I used a lil RTV n a wire tie to hold the sensor, cause the adjustment holes wouldn't line up.
+1 on redkk58 easy method. Get one screw in, RTV, a hose clamp over the whole mess at 28* and call it a day.
My SPE 40 came set at 45*. It was easy to adjust because it(the sensor) was mounted in a split ring clamp from the factory. There were no holes in the front bearing ring.
