No.
The center one way lets the front diff act the same as it always does - drive one wheel - the one with the least traction. The front one-way drives BOTH front wheels, independently, which improves control. Having both a center and front one way is redundant, because they DO NOT complement each other. The extra one way is just more complication, that's all.
If you want to locate CS parts for the TA06, try CS Junkies. You might be able to get some sources for parts there. The TA06, however, doesn't have much available for it, at the moment. You can also try a vendor that goes by the moniker "kaw218" on Ebay. H sells CS parts for different manufacturers. He might be back selling, as he took a break for a bit. Check to see if he's back up. He's the one I got that 1.60 CS kit for my VDF from.
