What I was trying to say is, that a front one way by itself is sufficient. A front one way is the thing to have. A front one way and center one way are much the same in operation, but not purpose. A standard diff and center one way are not as efficient, nor will control the front wheels of a CS drifter, as a front one way alone.
A front one way AND center one way are the redundancy, meaning the center one way is not required, but won't hurt anything, nor add to the front one way's duties. So, even if you have a center one way pulley, without a front one way, it will NOT be as efficient as a front one way, period. The "hand brake" effect is still there, but the independent front wheel drive aspect is not, and that's where the extra control comes from.
I hope that made it a bit clearer.
Yah, try Eagle Racing. If you can't find the pulley you're looking for, it probably isn't available anywhere, because it isn't a required pulley for CS conversion.
