RCU Forums - View Single Post - Pull-Pull system advice needed...
Old 10-30-2013 | 10:27 AM
Zor
Banned
Originally Posted by Rodney
No, if the horns on the rudder is aft of the hinge line (and the servo arms are on the center) you will get slack in the unpulled line as desired for positive Ackermann. Eckart is correct.
Rodney,
I agree that doing it at the rudder or elevator will work fine.
I used to do it at the servo because it is easier to install a new servo arm if the amount of differential has to be changed.
I find it easier than moving the horns at the control surfaces which have already been drilled in position.
Thanks for bringing this up.
Zor
