RCU Forums - View Single Post - Pull-Pull system advice needed...
Old 10-31-2013 | 10:10 AM
  #33
DaleJEckart
Originally Posted by VincentJ
All of my planes have the pull-pull system criss-crossed, it usually does give a better straight shot to the control horn. I run all of my wires through plastic antenna tubing so they do not rub against each other.
Good diagrams Sensei...
I'm liking that install... not quite sure why, but the tailwheel does NOT turn off the rudder, I need a seperate control rod for the rudder... but I will run it off the same servo, just in a hole from the rudder clevis.
