RCU Forums - View Single Post - Just got my first Plane!
Old 10-31-2013 | 10:49 AM
CARS II's Avatar
CARS II
My Feedback: (7)
Jonathan
You only need to read the first three or four postings, those are maintained by the creator of the post, he takes only the important comments from the thread and brings it to the front 3 postings.
I did one or two more mods that are not poste there just because I knew I was going to push the Bixler hard also wanted to make it easy to assemble, at the same time it is small enough to keep it assembled.
I have a Spectrum DX6i flying mine, the software should be almost the same, I use dual rates and I have a mix AIL/RUDD that I can turn on and off with a switch for coordinate turns and rolls, I highly recommend the APC prop as the original one is just a toy also a small drop of blue locktight on the two screws holding the motor to the motor mount ( I can show that with a picture ).
If you like to see my mods I can take pictures to show, also I could give you the specs on my set up if you need it, let me know.
