RCU Forums - View Single Post - I need some tips
Old 11-01-2013 | 11:54 AM
  #77
ToraKitsu
Here's a couple of pics, to show you the similarities between the TA06, and the Losi JRXS Type "R", and the CS mod I did. As far as I'm concerned, the two are "kissing cousins." They are also, in my judgement, the best on-road chassis for multi-purpose on-road use.
Tensioners can be made with a couple of 630 bearings, and a 2mm screw and nut. The tensioner in the pic is just a stainless screw, two 630 bearings, three proper-sized washers, and a nut to fit the screw. That's it!
Yah, if you ever decide to outfit the TA06 for grip driving, use the anti-roll bars then. They definitely help in grip driving!
ID:	1935696   Click image for larger version
ID:	1935697   Click image for larger version
