RCU Forums - View Single Post - I need some tips
Old 11-01-2013 | 01:11 PM
  #96
ToraKitsu
O.K., then you haven't. You need more than just a one-way to CS. The one-way doesn't CS. You need to alter the ratio at which the rear wheels spin, as opposed to the fronts. It's also called "Rear Overdriving," meaning the rear wheels spin at a faster rate than the fronts. CS is delineated by a "ratio," or the amount of added wheel travel the rears spin, than the fronts.
Now take the pic of the rear pulley and belt arrangement I posted. That is CS (though a very mild one). The pulley is smaller than the one it originally came with. That effectively altered the rear wheel speed by one-third of a revolution, or 1.33. That means that the rear wheels spin at a rate of 33% more than the fronts. This is what allows you to "steer" into the drift, like a CS chassis is known for.
To mechanically CS a chassis, you need to swap out pulleys, and more than likely, a tensioner will have to be made, as well. The TA06 doesn't lend itself to CS easily, though I have seen examples of guys doing it to a TA06.
Check out "CS Junkies" online, to see some examples.
