RCU Forums - View Single Post - Just got my first Plane!
Old 11-04-2013 | 06:29 AM
AMA 74894's Avatar
AMA 74894
Moderator
Originally Posted by helicrazedout
i am loving those mods cars! i look forward to adding them in slowly but i have a big problem at the moment! Yesterday i took her for her maiden everything looked okay so i got my friend to hand launch her for me and i was on the controls. It immediately went in hitting the ground nose in. It did not even get to fly for 2 seconds. I am guessing the plane is nose heavy i mean i was giving it full power and pulling back a lot on the elevator and it still went nose into the ground. Luckily nothing broke i only have to re-glue the nose so i got lucky. Please don't tell me i need help from an experienced pilot cause i am still going this alone for now. Anyway i am really disheartened i really thought she would fly What am i doing wrong?!? i am guessing my center of gravity is off? i now see i missed a link from wishykid that may help. Please help thanks!
Jonathan
a couple of things... forst, that airplane would need to be EXTREMELY nose heavy for it to lawn dart like that... what is much more likely is:
1) the elevator moves in the wrong direction (when you pull the stick BACK, the TRAILING EDGE of the elevator should move UP)
2) the elevator is trimmed down too much (with your hands off the sticks and the radio turned on, the elevator should be trailing edge neutral / streamlined OR SLIGHTLY trailing edge UP)
3) with the bixler, you should launch with only 1/2 to 3/4 throttle the first couple of flights, with the down thrust and high mounted motor, full throttle tend to push the nose down.
to check the CG:
the CG should be set at 60mm from the leading edge of the wing, measured where the wing meets the fuselage....
make a mark on the bottom of both wings, 60MM back from the leading edge.
with the battery in place, put your fingers on those 2 marks and see if the airplane's nose drops (nose heavy) , tail drops (tail heavy) or stays basically balanced on your fingers (balanced)
if it's nose or tail heavy, try to move the battery around forward or aft until the airplane does balance.
my personal thought is that you had a combination of the above issues...
