RCU Forums - View Single Post - How do i epoxy the horizontal stab?
Old 11-11-2013 | 05:53 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Originally Posted by sensei
Properly position prepared stab in place and glue with thin CA followed by medium, that is all you need...
Bob
I found it funny that the best advise here was completely overlooked. Not only does the epoxy method need more prep and cleanup work it is actually a weaker bond then if CA were used. Ca penetrates the wood much better then epoxy does, alignment wouldn't be an issue as you could have tacked it in place, adjusted as necessary and then flowed thin CA into the joint when ready to make permanent.
