RCU Forums - View Single Post - How do i epoxy the horizontal stab?
Old 11-11-2013 | 08:24 PM
2walla
My Feedback: (10)
Originally Posted by speedracerntrixie
I found it funny that the best advise here was completely overlooked. Not only does the epoxy method need more prep and cleanup work it is actually a weaker bond then if CA were used. Ca penetrates the wood much better then epoxy does, alignment wouldn't be an issue as you could have tacked it in place, adjusted as necessary and then flowed thin CA into the joint when ready to make permanent.
You can lead em to water but you cant hold their heads under....
