I'm with you sensei for the most part. I do, however, always use epoxy on the firewall joints since glow fuel attacks CA. Otherwise, it's mostly CA and I have never had a problem with it on hardwoods, neither plywood nor basswood spars. However, as I said before I will use epoxy on tail surfaces where shear stress is an issue.
