@checho4 I am the guy who has posted the solution for a bipe on a 9303 and 9305 in the Miss Wind 50 topic. What has been explained here before is programming with a 7 channel receiver, but there is a different, better way with 8 or 9 channel receiver. The trick is that the radio recognizes to which type of a receiver it is being paired with and therefore adds certain programming features. Amazingly there is not even a single word about these features in the manual!
I am in the process of selling my Sickle and BiSide was very high on my list, but honestly speaking I will wait for some version 2. I am great fan of bipes and will definitively own one soon. It looks like that the future is with bipes, I have recently checked on the new Oxai web site and there are 2 more new bipes announced, HyBird and Acuracy, very nice!
So here is the programming solution, the biggest difference is that all 4 ailerons can be trimmed via the AUX trim. I have also explained all the other mixes needed for the Miss Wind 50.
JR 9303&9305 with 8 or 9-channel receiver bipe programming
The mix RTRM-FROL is active if you mate flap with AUX3. Now you can trim all 4 ailerons via aux trim switch, where down is right and up is left. The aile trim remains active and will still trim only 1 pair of ailerons.
Ch. 1 Throttle
Ch. 2 Right Aileron
Ch. 3 Elevator
Ch. 4 Rudder
Ch. 5 Left Aileron (Gear)
Ch. 6 Right Flap (Aux 1)
Ch. 8 Left Flap (Aux 3)
Model type ACRO. In the device selection I have set flaps trim to OFF and in the OUT line all channels to INH.
Wing type is set to NORMAL, and in the dual section I have mated AILE with GEAR and FLAP with AUX3, trim is set to ACT.
Prog Mix 3: AILE->FROL and under Pos0 set both values to +100%
Prog Mix 4: RTRM->AILE and under Pos0 set both values to +25%
Prog Mix 5: RUDD->AILE, Seba suggests +2% and -2% for both
Prog Mix 6: RUDD->FROL should be identical to previous mix
Prog Mix 1: RUDD->ELEV, Seba suggests +4% for both
Prog Mix 2: THRO->ELEV, Seba suggests 2-3mm down
Velco
