Originally Posted by
tuny
I'm using 20,5 x 10 on my 185. It could use a bigger prop. Runs great. More torque and more power than 175. And the CDI is HV
There's a 21 x 10 std blade width that should work super on the 185. Problem is the weight at around 200 grams. What it probably needs is a 3 bladed woodie at around 19x10. But you;d have to make your own....have not found a commercially available product and I've looked quite a bit
