RCU Forums - View Single Post - The Odd couple
Thread: The Odd couple
Old 11-15-2013 | 03:16 PM
Rex Ross
Default The Odd couple
You might be asking .... why is a post war Russian AT-T heavy duty tractor towing a WWII German Rheinmetall K44 artillery piece?
This needs a little explaining, so I used my imagination and fabricated a totally fictitious scenario that is not based on an actual event.
The problem is that the Russian AT-T heavy duty tractor is a post war (cold war) vehicle, and the K44 is a late WWII German artillery piece.
The only story I could think of to explain this combination was to call it a captured German cannon being towed to the Russian Artillery Museum in St. Petersburg, to be displayed as a war trophy.
Hey guys, It's one of those ...... "It coulda happened things" .....but that only sounds reasonable if you have had a few shots of Vodka.
My first idea was to build a Russian Voroshilovets artillery tractor towing a B4 artillery piece. After thinking long and hard about that project, I talked myself out of it. Finding suitable track for that tractor and howitzer was the big problem.I gotta work on a solution for that.
Then I discovered the Russian AT-T tractor, which could use the T-34 lower chassis, (not perfectly accurate), but it looked close enough for me, and it would be a lot simpler and easier to do than scratch building the entire model. I considered building the ML 20 as a towed artillery piece until I ran across the Rheinmetall 12.8cm K44 L/55. That's it ..... I was hooked.
The tractor was an easy build. I have two MSN T-34s and used the bottom half of one of them for this project. All I had to do was build the upper body.
Here is what I have so far. Just a little more detail clean up and it's gonna get a Russian armor green paint job (what else?). The cannon will probably get panzer grey.
ID:	1939524   Click image for larger version
ID:	1939525   Click image for larger version
ID:	1939526   Click image for larger version
ID:	1939529   Click image for larger version
ID:	1939531   Click image for larger version
ID:	1939533   Click image for larger version
