Originally Posted by
theguitar
You don't think that a .40-.50 will fly it? The smaller engine is way closer to my budget.
That size will fly it just fine. The OS 46 AX would be the best but the ASP or the OS LA series would be adequate as well.
Most models are grossly over powered. Watch a Cessna take off from a real airport and then watch the so called "trainers" at the model field. You'll see what I mean. Airplanes don't take off in a couple feet and go into a 70 degree climb.
Brian
