Hi Brian,
I really like the 0.3 veil but only when bagging and can squeeze every last xcess gram out of the stuff. The 0.2 on the other hand is so thin that it doesn't matter that much. Im sure you will be very careful and cognizant of the weight build up.
I also have 0.5 veil and this stuff is really thick. Almost impossible to build light with it. Probably needs to have dacron textile applied on outside to draw out the epoxy under vacuum.
Besides, the 0.2 ounce stock will produce a surprisingly stiff wing. You probably don't need it full span either....maybe to where the interplane struts attach. Wish you lots of luck and success
