Hi Matt,
Thanks. There is a lot in play here.
Not least amongst them is the totality of the wing inc,, relative chords etc.
I'm trying to get the wing centre to do the heavy lifting so to speak.
My LE will go from blunt-ish to sharp.
The only snap on my horizon for the next two years is one on top of a loop - avalanche.
Here one can slow the model right down,pop the nose and ,,,,, .
A really honest snap is the aim here.
I can cheat the LE a little at the tip if I think it's needed - I will see just how stiff this wing is first.
You are correct re needing large throws - I have some of that going on at present.
A problem with this is that the rate of rotation builds through the manoeuvre if high inputs are required to initiate.
So I'm trying to progress from a known reference. I'm experimenting as well.
Brian
