RE: Engine Incidence/ Engine Mount
You siad right = 0 then you said right = 2.
Let's skip that for now...
Make your mount, and place it on the rails. Look at it from the side. If the engine looks like it's pointing down slightly, you're ok, if it doesn't, just add a few washers (to the rear screws) between the ply mount and the rails, and that will give to down thrust.
