RCU Forums - View Single Post - Jetronics HF (High flow) valve problem
Old 12-01-2013 | 12:34 PM
zl1wn
Default Jetronics HF (High flow) valve problem
I am trying to fit a jetronics HF valve to an Airworld Hawker Hunter.
My problem is that air comes out of both outlet ports all the time, even though the small red LED is
switching as I operate the retract switch.
Whether the red led is on or off, air comes out of both outlets all the time.
Can someone please help me sort out how to operate the HF valve, so it works correctlt.
Input air, is going into the center of the 3 holes on the other side from the outlets.
Ross
Auckland NZ
