Jetronics HF (High flow) valve problem
I am trying to fit a jetronics HF valve to an Airworld Hawker Hunter.
My problem is that air comes out of both outlet ports all the time, even though the small red LED is
switching as I operate the retract switch.
Whether the red led is on or off, air comes out of both outlets all the time.
Can someone please help me sort out how to operate the HF valve, so it works correctlt.
Input air, is going into the center of the 3 holes on the other side from the outlets.
Ross
Auckland NZ
Ross
Auckland NZ
Problem solved. Although the tubing was being held very firmly by the connections on the valve, the tubing wasn't pushed in far enough
to make an airtight seal.
Best wishes to all
Ross
Best wishes to all
Ross
