What class are you flying? The planes were designed for different purposes. BJ has a very nicely thought out plan for his planes. Monolog, cheap, entry level aircraft including 2m. Flies great. Prolog, is the next step up to a glass fuse. Different wing, and flies very well. There are two versions, the original with the more aft canopy and the V2, which uses the same canopy as the Nuance. Nuance is next up, really great plane for Masters and even the P sequence of FAI. Episode and BiSide were both designed with the latest FAI sequences in mind. Incredible rudder authority. Both fly great, and both have their differences, but they are definitely better for the FAI class and both can be a little more work in the lower classes.
Arch
