RCU Forums - View Single Post - Servo neutral position
Old 12-04-2013 | 09:57 AM
ameyam
Default Servo neutral position
Hi,
was setting up a new model & while trying to set neutral for sometime, I found that the neutral position is not 90 deg to the servo body. No matter what I do, the neutral is slightly off. Further, the neutral angle on the lhs servo is not the same on the rhs servo as the servo arms are in opposite directions. I had seen this in the past as well and set it to exact 90 deg from subtrim but that results in shifting the neutral point which means the ailerons will deflect unequal & lead to non axial rolls. With the same problem on the elevators, the model may snap in 3d. The servos I am using are 5625mg and new. Is this normal & how do I correct this?
Ameyam
