Servo neutral position
Hi,
was setting up a new model & while trying to set neutral for sometime, I found that the neutral position is not 90 deg to the servo body. No matter what I do, the neutral is slightly off. Further, the neutral angle on the lhs servo is not the same on the rhs servo as the servo arms are in opposite directions. I had seen this in the past as well and set it to exact 90 deg from subtrim but that results in shifting the neutral point which means the ailerons will deflect unequal & lead to non axial rolls. With the same problem on the elevators, the model may snap in 3d. The servos I am using are 5625mg and new. Is this normal & how do I correct this?
Ameyam
Ameyam
My Feedback: (41)
Well there is always some difference between the servos and sometimes reversing (change sides) or switching arms will help, but one BIG issue I see is the servos you are using. IIRC that was the first digital servo Hitec came out with and they are notoriously bad at centering and difficult to program.
I'd start by replacing the servos and then get yourself a Hitec programmer (assuming you stay with Hitec) and set 'em where you want them.....
Actually, these are 2007 vintage servos but were in the box all along. Not sure wether they are prone to the problem you listed but I don't have any other issues with them. I picked up a few of these when a LHS sold out, so they were much cheaper than Tower and I don't intend replacing them
By the way, I have the same problem with a brand new 2013 7985mg I intend to use on the rudder. It's a single surface so it's less of a problem
Ameyam
Ameyam
If you are using a dual arm rotate it 180°. If a single arm remove it and use a dual arm, just remove the opposing end after finding the 90° end. All multi arms have a center in one direction. All single arms are made the same and depending on the direction will be off by one tooth.
I am using a GP aluminum arm with adapter. I tried a single stock arm as well. I didn't use the stock double arm. But the 7985mg was using the gp double arm with adapter
Ameyam
Ameyam
Tried that
Last time I had this problem & asked around on the field, the club trainer told me he had a "micro servo adjuster" and said he would "change the centre & save it into the servo". Don't know what he was talking about as I didn't make that adjustment on that airplane. Was he talking about the servo programmer?
Ameyam
Ameyam
It gets even more interesting! Not a few of the models mount servos linkage, and horns in such a way that the linkage and servo position does not form a rectangle at center position.
At least most of the newer transmitters have the ability to correct for many of the problems.
Well, I didn't and usually don't use the stock linkages. I used Dubro blak scale horns and Sullivan full thread pushrods. So I will get that rectangle if I can figure the neutral
Ameyam
Ameyam
