RCU Forums - View Single Post - Servo neutral position
Old 12-04-2013 | 11:20 AM
acerc's Avatar
acerc
If you are using a dual arm rotate it 180°. If a single arm remove it and use a dual arm, just remove the opposing end after finding the 90° end. All multi arms have a center in one direction. All single arms are made the same and depending on the direction will be off by one tooth.
